Brief Description: Tape Canopy Edges to Fuselage; Trace Rear Window
Once I had the canopy positioned properly against the reference lines I had marked on the skins, I duct taped the sides of the canopy securely to the fuselage. The plexiglass wants to push outward so this took a fair amount of tape. With the canopy securely in position, I traced the outline of the back window using the edge of the aft top skin as a guide.
Front right corner still needs some trimming to fit in the ears
Front left corner still needs some trimming to fit in the ears
Sides taped securely to fuselage, rear window marked
