Dan's Web Site
Date:  11-15-2005
Number of Hours:  1.50
Brief Description:  Rivet Cap Channels to F704 Bulkheads
I debated whether I should wait to rivet the cap channels to the F704 center section bulkheads until after the wiring but decided to follow the instructions and do it now. The final thing that I did today was drill a hole in the top of the left F704 bulkhead assembly for the spring and rod that is used for the canopy latch handles. Unfortunately, I couldn't install these without removing the forward handle, sliding the spring and rod into the hole in the handle first, then sliding the other end into the hole in the F704 bulkhead and then rebolting the forward handle to the support angles.
Left cap channel riveted to F704 bulkheads; Canopy latch handle spring installed
Right cap channel riveted to F704 bulkheads
