Brief Description: Drill Spacers for Canopy Hinges
Once both #12 holes were drilled in all of the spacers, the blocks were once again bolted to the F745 ribs. The 1/4" holes were then drilled in the ribs using the pre-drilled holes in the blocks as a guide.
Left blocks bolted to ribs and 1/4" hole drilled in rib
Right blocks bolted to ribs and 1/4" hole drilled in rib
