Dan's Web Site
RV-7A
Install Right Side Primer Fittings / Fab SS Lines
Repeat for the right side cylinders #1 and #3.
1.) Install AN4022-1 primer discharge nozzles in lower cylinder head ports
2.) Use copper tubing to get the right bends
3.) Use the copper tubing as templates in making the same bends in the stainless steel lines
AN4022-1 primer fittings installed in lower ports on right side cylinders 1 and 3
Copper primer lines for #1 and #3 cylinder - templates for stainless steel lines
Stainless steel primer lines for cylinders 1 and 3 bent to match copper template lines
RV-7A Home
2363
Ailerons
Assembly
Baffles
134
110
Big Dig
Brakes
Canopy Frame
144
152
Cowl
68
74
Electrial
120
96
96
Elevator
Filtered Air Box
Flaps
Forward Fuselage
460
Gear
Hangar
Hardware
Horizontal Stabilizer
Left Aileron
Left Flap
Left Fuel Tank
Left Wing
90
117
Panel
Photo Shoot
25
Right Aileron
Right Flap
Right Fuel Tank
43
60
Right Wing
84
Rudder II
Seats
Service Bulletin: No
Spinner
Systems
Training
Vertical Stabilizer
146
