Brief Description: Setting the wing Sweep and Incidence
After the the fuselage is perfectly level on the cockpit sides, front, and back; the instructions say you need to "square" the wings with the fuselage. This is accomplished by placing a cleco in the bottom-center of the tail cone and attaching a tape measure. Then you measure from cooresponding points on the wing tips and painstakingly jostle the wings until the cooresponding points on the wing tip are exactly the same distance from the tail cone cleco.
Electronic Level on Front Panel Rail
100 Yard Tape Measure Attached to Cleco in Tail Cone
Each Wing Tip to Tail Cone Measurement is exactly 15' - 9 5/8"
