Brief Description: Fabricate and install the rudder pedals and brakes
There were numerous parts that had to be fabricated, drilled, deburred and assembled to make up the dual rudder pedal/brake assembly. I also had to make a make-shift seat from chair cushions. I drilled numerous holes 1 inch apart for side bearing blocks in case I have to move the pedals once I get the final seat cushions and interior completed.
Fabricated rudder pedal parts
Make-shift seat to determine leg room
Multiple holes for varying rudder pedal adjustments
