Marlins Web Site
Date:  1-27-2023
Number of Hours:  6.00
Manual Reference:  N/A
Brief Description:  Install Cabin Heat Muff and Tubing (Cont.)
When I reinstalled the heat muff after disassembling to fill with steel wool, I was concerned it was still slightly loose-fitting on the exhaust pipe. I safety wired the entire muff to a clamp securing the #2 cylinder Exhaust Gas Temperature (EGT) sensor. The 2nd picture shows the Scat Tube secured to the engine frame with two cushioned clamps and then terminated onto the Cabin-Heat-Inlet Assembly.
Heat Muff Safety Wire
Scat Tube Connected & Secured
Scat Tubes prior to RTV
