Once again, its time to fix yet another screw-up in VAN’s plans. As I was building the rear baffles on the passenger side of the engine, the plans specific for the IO-360 M1B engine showed the flange for air to go to the exhaust heating baffles, then into the cockpit mixing valve was mounted on the rear baffles. Now, the plans for the heat exchanger for the IO-360 M1B engine shows that same flange is supposed to be mounted on the front Inlet Floor Baffle. So, I had to remove the flange and replace it with a patch…GRRR.
