Brief Description: Installed New Electrical Boots & Engine Ground
I installed a solid copper connector and new boots between the Master Battery Contactor and the Starter Solenoid Contactor because I felt my previous connections placed unnecessary strain on the Contactors and the new boots will protect the electrical connections from inadvertent shorting, since they are exposed near the battery housing. I also installed the Engine ground wire from the firewall to the engine block; mounting dual Adelle Clamps to hold the wire to the engine mount framework.
