A couple years ago, I purchased a fuel Pump Cooling Housing/Shroud. To get the housing mounted, I had to remove the fuel pump and all the fuel lines. As you can see from the pictures, it wasn’t easy to install when the engine is mounted. The housing is the gold-colored object. At the same time, I installed the Fuel Flow Sensor (red colored) and had to order new insulated fuel lines, because the one’s from VAN’S were not the correct size. I mounted the fuel lines on the intake manifolds using duel Adele Clamps and drilled flat pieces of 1/8” aluminum to attachment to the engine-block.
