Marlins Web Site
Date: 4-12-2021
Number of Hours: 5.00
Manual Reference: Sec 9, DWG 41
Brief Description: Fiberglassing the Windscreen
The dreaded time has finally come to fiberglass the windscreen. As usual, VAN’s original RV-7 instructions for this process really suck; however, my friend who is building an RV-14 has excellent instructions from VAN’s for fiberglassing the front part of his tip-up canopy. I will follow those instructions, making modifications as-needed for my sliding canopy and windscreen. So, the journey begins… The first thing I have to do to fiberglass the windscreen to figure out where the edges of the finished glass-work will be on the edges of the plexiglass. Then, carefully mark a 2” offset line with a sharpie-pen onto the windscreen; all the way around the front, sides, and top. I did this using a scribe I modified to hold a sharpie. Next, I carefully applied electrician’s tape to the inside radius of the scribed line. NOTE #1: To those of you who are starting this process and reading my posts; USE HIGH QUALITY 3M ELECTRICIANS TAPE WITH A SUPERIOR GRIP; not a cheap brand from Harbor Freight or LOWES. In about 40 pictures and a lot of wasted time and frustration you’ll see why! I then applied a second layer of electrician’s tape over the 1st layer (you’ll see why soon) and overlapped cheap duct tape onto the existing protective plastic of the windscreen. NOTE #2: DON’T OVERLAP DUCT TAPE PARTIALLY ONTO THE CHEAP ELECTRICIAN’S TAPE AND THE OLD CRINKLY PLASTIC ON A WINDSCREEN THAT IS A BAZILLION YEAR’S OLD. Next, I carefully sanded the windscreen and aluminum skin forward or (outside) the electrician’s tape and with 60 grit sand paper to allow the fiberglass to adhere. Finally, I tied bags of sand together and sat them on the windscreen to weight it down for the best fit.
Electrician's Tape applied
Weighted Sand Bags for Fit
We're Havin' Fun NOW!
