After reinforcing the insides of each of the wheel pants with 3-4 layers of fiberglass, I redrilled the mounting bracket holes and redrilled the tire air-fill access holes, as well as the towbar holes for the nosewheel. Next, I marked the main wheel leg upper and lower fairings where they will need to be cut for final fitting and added two more layers of fiberglass cloth. I decided to set all the wheel pants and fairings aside for a while and will start on fiberglassing the windscreen.
