Brief Description: Completed sample of spreadsheets I developed
Earlier last month I completed a spreadsheet that lists every electrical part and the wiring needed to connect it to other components, power, and ground. As each item is complete I turn the color from all-white background to green. The other spreadsheet is every step required to complete the wiring. The 2nd picture is the integration wiring diagram I built to make sure everything is properly connected to achieve integration. As I am doing the wiring, I color the connections to triple check I am making all the correct connections. This maybe seems a little anal to someone looking at it, but it has prevented many wiring mistakes and it made me think through the entire wiring process to achieve optimum integration. The last picture is I at the computer updating the spreadsheets as I work on the airplane.
