Brief Description: First wires routed to the dropdown terminal panel
I had already routed and completed the wiring for the lighting dimmers, switches and numerous panel lights/map lights before I decided to add in a dropdown terminal panel. So with the addition of the dropdown terminal panel, I had to spend quite a few hours cutting wires, adding terminals & labels, and re-routing these to the new terminal panel I fabricated. It took a little while to figure out placement for wires but now that I have a system figured out, it looks pretty good and will be easy to troubleshoot or replace equipment if I ever need to.
