Brief Description: "New & Improved" terminal end, hinged, drop down p
The rest of the pictures of the "New & Improved" terminal end, hinged, drop down panel mounted. It is very securely mounted and braced. It is held in the "Up" position using flush mounted screws and nutplates. The hinged bracket allows it to drop down for access in front of the rudder pedals. Should work very well...I'll take more pictures once I get all the wires attached.
Drop down panel mounted
Underside of mounted panel
Drop-down panel in the "down" position for maintenance
