Michaels Web Site
Sonex Standard Gear
Cutting the right cowl
So the overlap shown in photo #2 will need to be cut away, and some fiberglass will need to be added to the edge that rests against the windshield.
This should make everything fit much better!
CUT!
With the upper cowl laid in its correct position, see the overlap that needs to get cut away.
RV-7 Home
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
