Michaels Web Site
Sonex Standard Gear
Connect upper cowl halves
- A little more trimming, then
- Duct taped the upper halves together.
- Made a channel (for rigidity) and riveted it to the upper cowl halves while they were in place on the aircraft.
- Now I could remove the cowl and prepare it for fiberglassing together.
Channel riveted to upper cowl halves.
From underneath, after removal from the aircraft
From the back, with the channel in place.
RV-7 Home
Sonex Standard Gear Home
2445
Aluminum Materials
45
Angle Parts
63
126
132
Bending Brake
85
Cowl
84
99
179
233
Finish-Polish
66
85
FLIGHT!
382
Hardware
95
Learning Point
111
Smoke System
Upholstery
638
