Time to get back to work on the L. wing. Got the leading edge out of storage and put it into the construction cradle. The "OP-46" Stall warning system gets installed into the leading edge. So, i got the switch mount installed and match drilled. Then, i disassembled the leading edge. De-burred all edges and holes. Then removed the vinyl from the rivet lines.
