Time to begin work on fuel lines. Looks simple enough, but there is a real learning curve to bending the tubing and having it fit! Took a couple of try's to get the first lines done.
Moved on to the first long vent line. I made a wood block with a groove cut into it that i used to straghten and clamp the line as i bent it. This actually came out pretty good considering all the complex angles i had to work with. I left the floor end slightly long so i could mark the final length in place. Then add the fittings and flare them on the bench.
