Mikes Web Site
Date: 2-12-2016
Number of Hours: 4.00
Brief Description: Fuel tank plumbing
After MUCH thought, research, and coin tossing I FINALLY settled on a fuel plumbing layout. The new ICP fuel system simply ties the outboard and inboard tank together, leaving one fuel line exiting the wing root. I really don't know if I'll ever want to isolate the tanks from each other or as inboard outboard pairs, but I really appreciate the simple, less pilot error of ICP's current layout. All tanks are tied together, including a seperate cross flow line, leaving one simple ON-OFF valve on the floor of the fuselage between the pilots legs in case of emergency to shut off the flow fo fuel to the engine. However, I liked the idea of controlling/isolating tanks, but wasn't sure I needed a complex fuel manifold to manage and risk forgetting during a distraction in flight. So...
I tied the tanks together at a T right under the access panel which should make it easier to seperate the tanks in the future should I prefer. As is, I assembled, plumbed, and pressure tested my entire system... no leaks! I also discover when looking for conduit to run strobe/nav/landing light wires in the wing, that the same mobile home plastic light weight water line also allowing the corrugated aluminium fuel tube to just slip into it. I decided to run the solid aluminium tubes throught the plastic lines as an extra measure of vibration/abrasion protection and support. With some encouragment, this doubled up arrangement still fit through the factory supplied rubber grommets giving me double protection when traversing any of the structure.
tank plumbing
Outboard tank connection
Outboard joins inboard tank
