Brief Description: Continue Install of Door Lock on Left Door
1. File the Door Handle pocket for the C-Rack 2. Grind a bevel on the top C-rack. 3. Cut the front and rear door pin rods to size. 4. Install and time Door pins. 5. Mark and drill 7/16 " holes in the Door Frames. 6. Mark, drill and countersink the holes in the UHMW door jam blocks. 7. Trim Door jam blocks and sand the door pin holes for smooth operation.
