1. File the slot in the VA-197 Door Handle Assembly to enable the roll pin to slide freely. 2. Sand with 400 grit paper the interior of the WD 1022 Handle to allow C-1007 Handle slide to move freely. 3 Install the VA 107 Spring and Roll Pin to the Door Handle 4. Cut the Vans C-Rack in half- de burr and install LP 4-3 Rivet to the bottom rack. 5. Sand the UHMW Planearound Door Block to fit the Front and rear door pockets. 6. Match drill the UHMW blocks and Counter bore the rear bloct for the Bolt postions. 7. Drill and file the holes into the latch pocket for the front and rear C-Racks.
