Leos Web Site
Date:  12-28-2017
Number of Hours:  5.00
Brief Description:  Reinstall G5 to recess
I had the G5 installed directly to the fiberglass center stack. This presented three issues that I wasn't happy with. 1) The G5 bezel is about 1/4" taller than the other instruments in the center stack and looked out of place. 2. The fiberglass is somewhat flexible so the mounting is not as solid as I would like. 3) I wanted the fiberglass to be removable as a bezel without having to remove all of the connectors and the pitot and static lines.
Creating a mount directly to the aluminum under structure was extremely tight with everything else going on in the area. As with all things on the airplane, time, thought and careful work made for a solid mounting solution
G5 mounting completed
Center Stack
Center Stack
