Brief Description: Securing and protecting wiring.
With the Airflow Pump work finished, I decided to protect and secure all the wiring in forward fuselage before installing the engine and nose gear. It will be good to do this now in the event I have to change something.
I protected the wiring coming through spar and gear mounts using split flexible conduit. All the wiring covered by the pump and forward fuselage tunnel cover are also protected in the conduit . The fuel quantity wires will have spiral wrap and conduit to protect them to the sender connection. This is all going to take quite a bit of time.
Wires passing through gear mount.
Fuel sender wire in spiral wrap will have split conduit.
Wire under the pump and tunnel cover in split conduit.
