Brief Description: Installed #3 Aft baffle with mid engine bracket.
I began installation of the #3 aft baffle which connects to #4 aft baffle at mid-engine with a bracket that uses engines bolt to fasten to the engine. The aft baffles also bolt to the rear of the engine as well as to each other at the bracket.
I had to grind a notch into the bracket to give clearance to the #4 cylinder fuel injector tube. It seems that everything has to be slightly modified to make things fit. Oh, well, no one said it was going to be easy!
Aft baffles bracket notched for injector tube.
Zoomed out view of injector tubes.
Aft baffles installed except for drilling holes for ignition wires.
