No pics but I came in and started sanding first thing this morning. The epoxy didnt quite harden completely enough for sanding due to the humidity and cold that came in. So the paper was gumming up real bad and the sanding just wasnt working out real good. I got the thing sanded with 80 on the lignt side but decided to let it sit today before sanding with the 150 grit paper in prep for some sanding primer i want to apply. I want to see if the pin holes are filling in after all this work!
