Bill & Brendas RV-8 QB
Date:  10-4-2014
Number of Hours:  1.50
Brief Description:  Bottom cowl primered with coat 1
I was slow to start today. Flew the Citabria and then hung out for awhile before getting busy with the sanding. I then cleaned up the surface and applied a single light coat of sanding primer. After it dried, I wet sanded it. I can see that there are more scratches visible from the 80 grit paper than pin holes. I will apply a second coat and sand it and then determine if I can live with the scratches showing or not. I can say that im happy to be rid of the pink exterior!
Pink be gone!
Pink be gone!
