Post 2/2 and no pics I failed to check the guide pin evenness in the propper hub after pounding on the spacer.The steel dowel pins are 2 inches in length and should have 1 inch in the propellar hub after install. If not it is recommended to pound the dowel pin to equal distance. I removed the bolts securing the prop and just set my micrometer into the hole until it bottomed out on the dowel pin. Turns out I have the pins in the hub with in 1/64 inch of equal parts and from one another. I wont bother with trying to adjust that small of a difference. Reinstalled the 6 bolts and sugged up. I probably wont torque until after the spinner is done.
