Bill & Brendas RV-8 QB
Date:  4-23-2012
Number of Hours:  1.75
Brief Description:  ELT mount -final
This is very hard to get to and took some time but I got the upper bracket installed. Had to match drill another hole for the cherrymax rivits. Installed the rivits with hand squeezer
The bottom bracket became a problem when I discovered that the hand squeezer did not have enough room. Drilled out the holes on the lower longeron to 11/64 to take #8 screws.. Installed using 3 #8 threaded screws and nylon locks
Attached the mounting plate and ELT to the angles
Need to decide how I want to run the Antenna coax cable and the remote switch line.
Upper longeron angle bracket installed with cherry max rivits
Lower longeron angle installed using AN hardware
ELT and tray mounted to the longerons
