Bill & Brendas RV-8 QB
Date:  1-17-2012
Number of Hours:  1.00
Brief Description:  Rivit left fuse skin to upper longeron from rear s
1. Noticed that a tab on rear seat back lower bulkhead was not drilled so I didi that first and then set all the rivits along that side up to where the front top skin will need to rivit on. I saved the rivits behind the front seatback support flange for last.
2. I learned from yesterday that the hardest part of rivitting in that tight spot was that the rivit bar is to short. I taped on several tongue depressors to it and that allowed me to easily position the bar over the rivit. Once in position, I only had to apply pressure higher up on the bar by reaching through a lightning hole. This worked well. A small light and mirror laying on the arm rest helped too.
Rear leftside lower bulkhead tab wasnt previously drilled
Bucking the rivits along top longeron along side rails
Some tounge depressor extensions for the bucking bar helps make positioning the bar much simpler
