Bill & Brendas RV-8 QB
Date:  4-12-2012
Number of Hours:  0.75
Brief Description:  Wing T405 bracket cuts
After drawing parallel lines from the hole in T 405 bracket out from the bolt hole, cut the slot with dremel and then filed until a smooth surface and even 1/4 inch width of slot. This is for the bolt to slide out if the wing hits an object and pushes back it will not tear open the fuel tank. Thats what they say anyway...
