Brief Description: changed pitot aluminum to plastic transition in wi
I did not like the cheap look of how I attached vinyl pitot line to the aluminum pitot line in root. I had purchased these fancy quick connect connectors awhile back and was assured this application would work. I did a simple test and they sem to work as advertised.. I will be using these on the static connection to gauges as well.
