Bill & Brendas RV-8 QB
RV-8
Left triling edge evened out in line with TE of ai
I put a straight edge to the aileron and marked continuation across the wing tip surface.
Used power sander and long block to sand to the line. I then hand rounded the trailing edge.
I will finish it up better when its a bit cooler and also add some reinforcement glas to inside to reinforce what I removed.
Left wingtip TE marked in line with TE of aileron
block sanded to line and reformed the radius
flush wing tip TE with aileron
RV-8 Home
2332
baffles
brake system
Canopy skirt
Canopy/windscreen
cowling
electical-FWF
Electrical-cockpit
Elevators
Exterior lights and
FAB
Fiberglass fairings
Fiberglass tips
329
Horizontal Stabilize
interior cushions an
Inventory
jigs, cradles, stand
Kit arrival
labels and plackards
Landing gear
Lights
Panel
paperwork
phase one tests
Practice kit
practice kit or tria
Propeller/Spinner
Seats and floors
Vertical Stabilizer
weight and balance
Wing Fit/install
Wing Fitting
wing tip lights and
Wing Tips
123
Wire work
Wiring behind panel
wiring-cabin
