Brief Description: Cut panel for garmin 696 air gizmo mounting trey
1. Carefully positioned and measured and then marked with a scribe the cut out lines for the Air Gizmo mount that will hold my Garmin GPS 696
2. Marked then center punched for drilling the radius in each corner. Started with #40 and then finished with #12
3. Set up for cutting by clamping my steel back rivit plate to each scribe line and then useing it as a guide to make the necessary cuts with my dremel. I was a bit too carefull and left way too much to trim down to the line
4. Filed cuts down to line and polihed edges and corners
