Brief Description: Counterweight repair, ASI repair-1
1. Early in build I made the mistake of cutting both counter weights when only the right side was to be cut. I had saved the piece and today I epoxy it back on. When dry I will secure with a counter sung screw
2. Fileing the edge of rt counter weight to countour with the skin
3. I trying to fix the ASI, I need to thread the remaing stub with a # 2 die. I need to somehow secure the stub so it doesnt turn while I thred it. I drilled a scrap of aluminum and epoxied on to the stub. When dry, I ll try to thread it.
Epoxy lead piece on to the left elevator counter weight
