Bill & Brendas RV-8 QB
RV-8
Fuel system -1
1. Filed off the pointer on fuel valve lever per instruction. The lever will act as the tank position idicator.
2.Made 2 spacers and cleaned edges etc.
3. Install the fittings called for in the fuel vale.
4. Drilled the holes in fuselage bulkead to 7/16 and installed the 45 degreee elbow bulkheaed fuel line fittings.
5. Cleaned up the edges of 1 of two airflow brackets and then clecoed to the left side flor board and drilled the 4 holes to #30
Pointer filed off fuel selector lever
AN fittings installed and adjusted to proper positions
Airflow bracket cleaned up, clecoed to floor, drilled to #30
RV-8 Home
2332
baffles
brake system
Canopy skirt
Canopy/windscreen
cowling
electical-FWF
Electrical-cockpit
Elevators
Exterior lights and
FAB
Fiberglass fairings
Fiberglass tips
329
Horizontal Stabilize
interior cushions an
Inventory
jigs, cradles, stand
Kit arrival
labels and plackards
Landing gear
Lights
Panel
paperwork
phase one tests
Practice kit
practice kit or tria
Propeller/Spinner
Seats and floors
Vertical Stabilizer
weight and balance
Wing Fit/install
Wing Fitting
wing tip lights and
Wing Tips
123
Wire work
Wiring behind panel
wiring-cabin
