Bill & Brendas RV-8 QB
RV-8
Install elevator trim tab servo and adjust. Test t
Installed the trim servo
Cut the pushrod to length and installed the two clevis and safety nuts
Attached the pushrod assembly to the servo and tab horns with the clevis pins and washers and cotterpins
Used a 9 volt battery to test full up and down deflection. No binding noted.
RV-8 Home
2332
baffles
brake system
Canopy skirt
Canopy/windscreen
cowling
electical-FWF
Electrical-cockpit
Elevators
Exterior lights and
FAB
Fiberglass fairings
Fiberglass tips
329
Horizontal Stabilize
interior cushions an
Inventory
jigs, cradles, stand
Kit arrival
labels and plackards
Landing gear
Lights
Panel
paperwork
phase one tests
Practice kit
practice kit or tria
Propeller/Spinner
Seats and floors
Vertical Stabilizer
weight and balance
Wing Fit/install
Wing Fitting
wing tip lights and
Wing Tips
123
Wire work
Wiring behind panel
wiring-cabin
