Jims RV-8
Date:  2-4-2024
Number of Hours:  2.50
Brief Description:  CPC PIC stick attach work
I cleaned the shop and started working on where the CPC for the pilot stick would attach. I considered a few options and settled on the same place Bob used, under the seat ramp. Bob even provided the attach hardware - so I was halfway there! It was a matter of finalizing the location, then drilling the nutplate rivet holes and riveting them to the hardware. I widened the opening a bit more so that I could pull the CPC out if needed without loosening the wire bundle screws, which will make it quicker and easier to remove when needed. After that, I scuffed it with the scotchbrite pad, cleaned it, primed it, and then set it aside to dry.
plenty of wire clearance
seat ramp with countersunk screws attached to CPC hardware
more lacing and wire protetction on bundle
