Ivans RV 10
RV10
Fuel Lines
Step 1: Cut two 45 1/4 fuel lines from ATO_035x3/8 tubing.
Step 2: ASlid on fittings and flared one end of each line.
Step 3: Bent tubing by hand to get dimension as shown in figure 2, 37-3.
Steps 4 & 5: Made necessary bends in tubing to fit in tunnel and for exiting through the F 1004K-L Center Section.
Step 6: Positioned tubing in tunnel and fed other end out to center section. Placed grommits and adel clamps in place as tubing was installed.
Step 7: Installed adel clamps, grommits and F 1084B Systems bracket Clips to the systems brackets.
Step 8: Bent fuel lines 90 degrees back about 2 1/2" outboard of fuselage.
RV10 Home
519
Aileron Actuation
Ailerons
Auto Pilot
Baggage Area
Baggage Door
Elevator
Empennage Attach
Fairings
Flaps
Horizontal Stabilize
Inventory
Rudder and Brake Ped
Tailcone
Tailcone Attach
Vertical Stabilizer
Wing Tips
Wiring
