Step 3 & 4: Placed fuel pump and filter on brackets then tightend the hose clamps onto the pump and filter.
Step 5: Flo -Scan bracket mounted per QB kit.
Step 7: Made a fuel line to connect the Tee fitting on valve to the ES Airflow Filter. Made another line to connect the check valve on the ES airflow Pump to the middle leg of the Tee on valve.
