Completed all the welding on the aileron and idler brackets. Started honing the inner diameter of the bearing cages so the fixture plugs/KP4 bearings will slip in with mild hand pressure. Got the 1/4" aluminum plate today to use as a base for a jig to weld the bellcranks.
