Cut, deburred, bent, cut and deburred again the two aileron brackets. Used the HF 18" metal brake for these and it worked out great! Laid out, cut and deburred the bracket plates. Cleaned the layout fluid off with acetone except for the idler brackets. Forgot to mark and center punch the attachment holes. Everything is ready to weld together.
