Brief Description: aileron brackets and drill press set up
Laid out the two aileron brackets on .063 sheet. Set up an 18" harbor freight sheet metal brake and test bent a piece of .050. Not bad comparted to beating it out in a vice. The aileron brackets will be the true test. Right at the advertised limit for the brake. Set up the new drill press from Home Depot. 12 speeds that will allow nearly any kind of drilling work to be completed correctly. It was heavy!
