Finished fishmouthing. Used the stainless step to position the fittings on the longerons and a scrap of lumber as an aid to hold things vertically for tacking. Tacked and welded the fittings to 11.5 degrees. Worked out well, the step appears parallel to the ground when the fuselage is at a simulated 3 point stance.
