Finally got the baffles trimmed and fitted. only need to install nutplates on plenum and fit boots. Finalized the purge valve cable also. Got the stencils for the "N" number and other little decals installed today.
Turned my attention to the prop. Pulled the Saber spacer off, lubed oring and the torqued spacer in place. (used Blue locktite) Neil helped me installed the WW200RV prop and torqued it to 65# per the manual.
