Brian's RV-7 Web Site
Date:  9-28-2010
Number of Hours:  6.00
Brief Description:  Exhaust installed then various clamps, plug wires,
Tightened up fuel fittings. Installed CHT probes with antiseize, then routed leads to engine mount area. Rerouted ram air cable and secured it. Installed the exhaust pipes and hangars. Built brackets for plugwire routing to bottom cylinders. Other various firewall forward clean up items. Then pulled the plenum and worked on purge valve cable.
