After I replaced the brake lines with hoses, I had the bleed them. I attached a hose at the reservoir and let it end in a jar. I then pumped brake fluid in from the caliper on both sides until all air was gone. I tested the brakes via the pedals and they seem to work fine with a solid feel.
