Removed cockpit floor, disconnected aileron trim cable from spring pushrod and removed aileron trim control panel and cable. Secured both ends of cable to Adel clamps with safety wire. Rerouted cable into clamp; refit aileron trim control panel; reattached trim springs to control column and trim pushrod. Centered control column and aileron trim lever; cinched cable in clamping bolt. Aileron trim system function restored.
