Brief Description: Bolted Center Control Rod to Spar Brackets
With Walt's help, I bolted the center section of the control sticks to the main spar. Two washers were added on each side of the bracket on the left side. The bolts were torqued. The control sticks were temporarily attached to the center section. The stick was moved to the right and the aileron control rod was stuck in the full up position. The bolt in the aileron was taken out. The rod's bearing had been jammed into the lower edge of the opering. This will need to be checked into.
