Brief Description: Began to Cut Out Openings for Hartwell Latches
A template of the shape of the Hartwell latches was made and transferred onto the door. The Hartwell latches will be riveted onto the door and keep the oil access door closed. The shape of the latches was drilled out of the door with a #30 bit. The shapes were punched out and then the sides were filed.
